Hvordan fjerne plombering i kammeret(eksosanlegg)
Legg innav Christian » 01 apr 2008, 00:21
Guiden er riktignok på engelsk men den er lett å forstå om man setter seg inn i det!
Kilde: http://www.tjtuning.co.uk
Removing your CAT
You will need to take your expasion chamber off the bike (see manual if you dont know how)
You need to cut your expansion chamber open where this fella is cutting it and where the white
Once you have done this you will be able to remove the CAT
Thats it really, dont know too much about it because I havent done it... Just weld your expasion chamber back up with the CAT removed, give it a respay (heat resistant of course) because they tend to rust like hell even if you dont ride your bike in the wet.
The expasion chamber doesnt really have anything in it anyway if your thinking this was too simple. Literally just cut it open, remove the CAT and weld it back together.
Some exhausts also have a recirculation tube that goes to the air box. You just have to cut this off and weld it up and seal up the air box.
The snorkel in the air box can be taken out too, this will let some more air in slightly and make your bike sound a lot better. Just pull the rubber out the top, or you can cut the part that sticks out. This shouldnt affect your jetting since the bike is not jetted correctly from standard anyways. If you want to be sure stick a bigger main jet in (121 on a 28mm carb). Do a plug chop to confirm.
Viss du skal foreta en plug chop: http://www.dfn.com/benkaren/plugchop.html
Når du har montert anlegget husk å dyse OPP og stille oljepumpa OPP. Hvordan? Det finner du her: https://apriliaforum.torvald.no/viewtopic.php?f=13&t=30
General-Billy
Re: Hvordan fjerne plombering i eksosanlegg?
Legg innav General-Billy » 01 apr 2008, 00:27
NW Christian :P
[X] BMW 325D E92, 11
[X]Audi A3 1,8TQ 00
[X] Aprilia RS 125 07
Rider on the storm
Legg innav Rider on the storm » 02 apr 2008, 13:52
Det er jo et tynt rør i svanehalsen og, so bør fjernes! [-X
Legg innav Christian » 02 apr 2008, 15:35
Dette er såvidt eg har skjønt, hovedsaklig kun plomberingen i kammeret. Skal endre emnetittel!
Magnus
Vaktmester
MC: RS250 banesykkel en dag?
Re: Hvordan fjerne plombering i kammeret(eksosanlegg)
Legg innav Magnus » 03 apr 2008, 21:22
- oppdatert mars 2009
thomas880
Registrert: 03 okt 2007, 14:00
MC: Aprilia rs125, 2001'
Legg innav thomas880 » 05 apr 2008, 12:43
Burde man dyse om etter man har fjernet plomberingene?
Aprilia RS 250 Nero Diablo
Alecken
Legg innav Alecken » 05 apr 2008, 12:48
Jepp.. :)
Alt står forklart grundig i trimmeguiden under "trimming".
Tidligere admin/moderator
Mats
Registrert: 03 feb 2007, 12:32
Legg innav Mats » 05 apr 2008, 15:18
[X Sykkel] 2004 Aprilia RS 125
PeeWee
Legg innav PeeWee » 05 apr 2008, 15:46
noen som gidder tegne opp hvor en skal skjære for å ta ut alle sammen ? :P
Anders
Registrert: 12 aug 2007, 20:02
MC: 1999mod. Aprilia Rs 125 FP
Legg innav Anders » 10 apr 2008, 14:53
Må man stille opp oljepumpa når man gjør den uplombert? =S er vel to streker på oljepumpa, og de skal vel stå parallelt med hverandre, om jeg ikke tar feil nå..
Skaarud
Legg innav Skaarud » 10 apr 2008, 14:55
Man trenger ikke stille på oljen før sykkelen er FP, noe den er med uplombert anlegg og rave ;)
Anders
Legg innav Anders » 10 apr 2008, 15:21
Så dermed trenger jeg ikke å stille oljepumpa, kjører med RAVE 1 og FP anlegg..
Legg innav Christian » 10 apr 2008, 15:26
Still oljepumpa litt opp for å være på den sikre siden :wink: Men når den er FP skal pumpa stå strek mot strek.
Anders
Legg innav Anders » 10 apr 2008, 21:30
Mm, var det jeg viste, at den skal stå strek mot strek ; ) må få satt i enda større dyse i min, fordi den " kutter " på høyere turtall, fra 7.500 og opp.. irriterendes =/ tror den får litt lite bensin på topp ja.. 128dyse nå BTW
Skaarud
Legg innav Skaarud » 11 apr 2008, 13:42
DanielJohansen
Legg innav DanielJohansen » 19 nov 2008, 10:23
Noen som har en link til hvor ALLE plombene som sitter i en 07 svane er? :roll:
Eller er det noen som kunne forklart godt om hvor de sitter [-o<
Og hvor man kutter svana for å få de ut. :mrgreen:
Legg innav Christian » 19 nov 2008, 15:09
DanielJohansen
Legg innav DanielJohansen » 19 nov 2008, 15:19
ja, men skulle gjerne vist hvor/hvordan man fjerner de andre og :wink:
Legg innav Christian » 19 nov 2008, 15:28
Du må splitte hele eksosanlegget.
DanielJohansen
Legg innav DanielJohansen » 30 nov 2008, 16:38
Det har jeg skjønt, men HVOR skal jeg splitte det? Noen som kan ta et bilde å tegne opp hvor man skal kutte det? :roll:
Hadde vært til STOOOOR hjelp! [-o<
Skaarud
Legg innav Skaarud » 04 des 2008, 22:04
Splitt det i sveiseskjøtene??
DanielJohansen
Legg innav DanielJohansen » 15 des 2008, 21:51
Ja i dag tok jeg å en kompiss av meg å fjerna plombene i anlegget mitt!
Vi kutta anlegget i sveiseskjøtene, og borret et lite hull inn der hvor den største plomba var sveiset fast. Dette måtte gjøres for å få delene fra hverandre!
Men så var det en ting jeg lurte på og, den nettingen som er litt etter midten på anlegget, bør jeg fjerne den? :roll:
Da tenker jeg på om jeg får mer effekt hvis jeg fjerner den. Og om lyden blir veldig anderledes :P
Legg innav inunf » 15 des 2008, 21:57
Ribb ut alt. Pass på å få jevnest mulig kanter inni ekspansjonskammeret. Det er fortsatt dobbelt lag med stål for å dempe lyden, så du får ikke klinge-lyden fra et effektanlegg.
Rider on the storm
Legg innav Rider on the storm » 28 des 2008, 13:01
Du fikk det til ja! :D .
Burde vert lagd en skikkeli guide om dette =D>
DanielJohansen
Legg innav DanielJohansen » 28 des 2008, 19:56
Jeg fikk det til ja!
Takk for hjelpen rider on the storm :D
Rider on the storm
Legg innav Rider on the storm » 29 des 2008, 20:25
Allti gøyt å hjelpe :D
bronstad93
Legg innav bronstad93 » 27 jan 2010, 20:32
tenkte på å gjøre dette selv nå, men skal absolut alt inni potta ut? insnevringsrøret under svana, catalysatoren og gitteret ?
(X) `98 Honda MT5
(X)`89 Suzuki tsx
A1: 21.06.10
B: 30.11.11
fossumjr
Registrert: 28 sep 2009, 19:15
Legg innav fossumjr » 12 sep 2010, 02:49
hvor måtte du borre ? : D
Aprilia RS 125 SF arrorw potte - power filter - 125 dyse
sachs xtc 125 rakrør
bronstad93
Legg innav bronstad93 » 12 sep 2010, 13:21
måtte borre ut 2 popnaggler og sveise igjenn hullene ;)
(X) `98 Honda MT5
(X)`89 Suzuki tsx
A1: 21.06.10
B: 30.11.11
fossumjr
Legg innav fossumjr » 12 sep 2010, 16:23
ty ;*
bronstad93
Legg innav bronstad93 » 12 sep 2010, 18:14
np :D kjørte fra rs`er med giannelli og nsr`er med jollymotto bare ved å ta plomben i eksosen! :D
(X) `98 Honda MT5
(X)`89 Suzuki tsx
A1: 21.06.10
B: 30.11.11
ktm4ever
Registrert: 14 nov 2012, 00:25
Legg innav ktm4ever » 18 nov 2012, 05:11
Tok selv ut denne sinnsvake ideen som ikke hører sammen i et 2takts ekspansjonskammer.
Først så har de ikke klart seg med den første plomberingen du ser i begynnelsen på eksosanlegget men når man kapper opp det langs sveisen på siden og man borrer evt kapper de to sveisene etterhverandre uten på anlegget og ser så har de kastet in et rør som skal føre eksosen rett inn i katalysatoren og denne har en kappe rundt som ligger sveist intill veggene i eksosen seg som ødelegger hele "tilbaketrykket" ekspansjonstrykket totakteren må ha for og fungere optimalt.
Jeg kappet/slipet vekk ALLT de hadde montert inni der , katalysator med kappe, rør , hele nettingen og jeg pusset vekk alt av sveiser og nupper som stakk ut og som kan skape en endring i Flowen. ;)
Jeg anbefaler ALLE som har planer om et ekte Italiensk annlegg såkalt FP/Full Power eksos om og gjøre det samme for og få optimal effekt ut av eksosanlegget. Mange hester og hente!!
Jeg skal legge ut bilder her av det , evnt lage et innlegg på guides om noen vill jeg skal O:)
2 Takt eksos videoer:
Hvordan lage 2-takt eksos fra start!
Visuelt forklart ekspansjonskammer funksjon
Ktm Sx 200 Knall sykkel!
Nylig kjøpt 2 RS125 prosjekt som jeg skal bryne meg på i vinter!
Gå tilbake til «Guider»
