Aprilia RS125 06/07
Alt nytt fra mc-verdenen postes her
Magnus
Vaktmester
MC: RS250 banesykkel en dag?
Aprilia RS125 06/07
Legg innav Magnus » 13 des 2006, 19:01
THE NEW APRILIA RS125 2007, THE SCHOOL OF CHAMPIONS
Aprilia’s know-how and technology have always led the way in the world of 125 supersports. Aprilia has regularly topped the sales tables with bikes that inspire young riders with the passion not only to dream, but to compete. The machine that symbolises Aprilia’s supremacy in the 125 market is now back, completely renewed in style and technology. The latest RS 125 is more supersport than ever, and is not going to be beaten easily. It has all the cutting edge technology, style solutions and aerodynamics of a real GP racer, and is totally unrivalled when it comes to developing your passion and skill, on the road and on the track. The new RS 125 is today’s bike for tomorrow’s champions.
NEW RS 125, RACING TECHNOLOGY
1. POWER AND RELIABILITY
The liquid cooled, single cylinder, two-stroke RS125 is the technical reference point for all other 125 cc supersports. Derived directly from Aprilia’s experience on the world’s GP racetracks, the RS 125 is totally reliable on the road and aggressively powerful on the track, thanks to advanced technology like crankcase reed valve induction and a vibration damping counter-shaft. The RS 125 is even homologated to Euro 2 standards, because performance and respect for the environment really can go hand in hand.
2. RACE-WINNING AGILITY
The RS 125’s sophisticated and lightweight frame is developed from the superb racing frames of Aprilia’s amazing 125 GP bikes. It is made from polished aluminium alloy, guarantees extremely high torsional rigidity, and delivers maximum control and agility under racing conditions.
3. COMFORT AND SAFETY
The upside down fork has been completely re-designed, as has the rising rate rear suspension. The result is performance, safety, and an impressive level of comfort in daily commuting as in racetrack use. The brakes are completely new too and represent the pinnacle of world production. At the front, the RS 125 boasts a four-piston, radial caliper front brake with aeronautical metal braided brake hose and a 320 mm floating disc. The 220 mm rear disc unit also features aeronautical metal braided hose for precise, balanced and powerful, GP style braking.
4. RACING WHEELS
The ‘Y’ spoke alloy wheels have six spokes at the front and five at the rear. These low weight, high strength wheels are fitted with tubeless radial tyres for unrivalled agility with guaranteed road-holding under all conditions.
5. GP SWINGARM
One of the most prestige components on the new RS 125 is its die-cast aluminium alloy swingarm. In addition to guaranteeing the highest degree of torsional rigidity of any production 125, the swingarm’s special design also lets you lean further than ever without touching the asphalt.
6. ADVANCED AERODYNAMICS
Aggressive, streamlined, and breathtakingly beautiful, the new RS 125 is born to win. Its styling is the result of advanced research into aerodynamics and extensive wind tunnel testing. It should come as no surprise, therefore, that the RS 125 affords excellent wind protection, and minimum air resistance. Everything about it is made for speed, from the latest generation, twin headlight nose fairing to the tail, with its aggressive, streamlined, integrated seat and powerful rear light cluster.
7. RACING INSTRUMENTATION
The compact and lightweight new instruments incorporate all the functions of a real racing unit, including an analog rev counter and a multi-functional digital display with handlebar controls to operate the tachometer, trip counter, battery voltage meter, clock and 20 lap timer, coolant temperature gauge and fuel reserve indicator.
I 2007 er modellen uforandret, men det har kommet en ny fargeutgave. Nemlig Poggiali Replica.
2006 og 2007
Sist redigert av Magnus den 23 des 2006, 00:07, redigert 1 gang totalt.
- oppdatert mars 2009
Lartreig
Legg innav Lartreig » 13 des 2006, 19:03
Du la ut en eget topic? :P Den røde er ganske fin syns jeg.
Sist redigert av Lartreig den 13 des 2006, 19:07, redigert 1 gang totalt.
DavidK
Legg innav DavidK » 13 des 2006, 19:06
Jøss, kommer de til å kjøre de to 06 fargene også, ENESTE jeg ser som er forskjell fra 06'en er at det AGIP klistre merket på toppen av kåpa på 07'en er helt nederst og bakerst på 06'en. Likte btw den nye røde fargen der :)
Sort BMW E46 Coupe "M3 style"
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Kay
Legg innav Kay » 13 des 2006, 23:08
var ganske fet den ja :P
vinne i lotto og så kjøper jeg meg en sånn eg :P
Aprilia RS99, soon gone.
Mathias
Registrert: 19 des 2006, 18:30
MC: Aprilia Rs 125
Legg innav Mathias » 21 des 2006, 20:56
veit noen om når 07 modellen kommer ut :?: :D
Lartreig
Legg innav Lartreig » 21 des 2006, 21:05
den kommer vel ut i 2007 den :P Sikkert i Januar februar eller seinest mars.
karlsen.90
Registrert: 11 des 2006, 15:06
Legg innav karlsen.90 » 22 des 2006, 00:36
Italian Animal
Aprilia rs 125 '05
Lartreig
Legg innav Lartreig » 22 des 2006, 00:39
Mathias
MC: Aprilia Rs 125
Legg innav Mathias » 03 jan 2007, 16:01
er det noen som vet når 06 modellen går ned i pris :?: :D
2bb1
Legg innav 2bb1 » 03 jan 2007, 16:17
Den vil ikke gå så alt for mye ned i pris da den er helt identisk med 07-modellen (hvis vi ser vekk fra den røde utgaven, som er rød^^). Bare løp og kjøp (og prut), du vil ikke gå glipp av to måneder av sommersesongen når du bare sparer en tusenlapp eller to ;)
Aprilia RS 125 2006
Mathias
MC: Aprilia Rs 125
Legg innav Mathias » 03 jan 2007, 22:01
2bb1
Legg innav 2bb1 » 03 jan 2007, 22:22
Aprilia RS 125 2006
Lartreig
Legg innav Lartreig » 03 jan 2007, 22:26
MC: Aprilia RS 250 2003
Legg innav Robban » 03 jan 2007, 22:32
Christensen
Registrert: 02 nov 2006, 18:34
Legg innav Christensen » 05 jan 2007, 13:24
Strive for perfection in everything you do. Take the best and make it better. When it does not exist, design it.
Lartreig
Legg innav Lartreig » 05 jan 2007, 14:37
Mathias
MC: Aprilia Rs 125
Legg innav Mathias » 05 jan 2007, 15:35
Christensen
Legg innav Christensen » 05 jan 2007, 15:44
Mathias
MC: Aprilia Rs 125
Legg innav Mathias » 05 jan 2007, 16:33
Lartreig
Legg innav Lartreig » 05 jan 2007, 17:08
Christensen
Legg innav Christensen » 05 jan 2007, 17:32
Lartreig
Legg innav Lartreig » 05 jan 2007, 17:34
Christensen
Legg innav Christensen » 05 jan 2007, 17:39
Lartreig
Legg innav Lartreig » 05 jan 2007, 17:45
Christensen
Legg innav Christensen » 05 jan 2007, 19:31
Harry
Registrert: 24 okt 2006, 21:50
Legg innav Harry » 06 jan 2007, 01:19
Aprilia rs 125 05 mod
Ærråv
Lartreig
Legg innav Lartreig » 06 jan 2007, 01:24
Christensen
Legg innav Christensen » 06 jan 2007, 11:51
miss pitlane
Registrert: 28 jan 2007, 02:48
Legg innav miss pitlane » 05 feb 2007, 10:21
Den røde utgaven så utrolig sprek ut :D
..eg lika trillbårÆ mi
Legg innav Robban » 05 feb 2007, 10:25
Ja, har helt klart sansen for den Poggialli replica'n :D
Lartreig
Legg innav Lartreig » 05 feb 2007, 16:01
En kammerat skal kjøpe seg den røde 07 modellen. Fy søren den er heftig :D
Tobban
Registrert: 11 jan 2007, 21:36
Legg innav Tobban » 07 feb 2007, 00:23
pics?
kjent for sandefjord's tyngste dreving og høyeste toppfart blant 125cc!
Aprilia RS, Try to keep up!
Lartreig
Legg innav Lartreig » 07 feb 2007, 15:18
Magnus
Vaktmester
Legg innav Magnus » 08 feb 2007, 14:49
Nice! Da får han vel en del tusen i rabatt da, siden det er demo-sykkel.
Lartreig
Legg innav Lartreig » 08 feb 2007, 23:56
han kjenner en av Aprilia importørene så han får rabatt uansett :P Han fikk den forrige til innkjøpsprisen.
Kristoffer
Registrert: 25 okt 2006, 14:55
Legg innav Kristoffer » 10 feb 2007, 16:39
Magnus
Vaktmester
Legg innav Magnus » 09 mar 2007, 19:03
DavidK
Legg innav DavidK » 09 mar 2007, 19:54
Ett utdrag:
"Honda's commercially successful, but bland and underpowered, CBR125R is clearly going to lose many additional sales to Aprilia buyers who understand that the RS125 is a real motorcycle and not just a mass market commuter bike with a nice fairing."
hahaha :D
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Mathias
MC: Aprilia Rs 125
Legg innav Mathias » 12 mai 2007, 20:46
APRILIA RS 125 07 spain's #1
Free Power
Tim
Legg innav Tim » 12 mai 2007, 21:07
Lartreig
Legg innav Lartreig » 13 mai 2007, 00:34
Syns de passer egentlig jeg..
Tim
Legg innav Tim » 13 mai 2007, 00:38
Lartreig
Legg innav Lartreig » 13 mai 2007, 00:39
Gå tilbake til «Nyheter»
