Aprilia RSV 1000R Factory 2007
Pålarn
Registrert: 19 jan 2007, 17:17
Legg innav Pålarn » 23 jan 2007, 18:33
This year's Master Bike has scientifically and conclusively demonstrated that the Aprilia RSV 1000 R Factory is the most efficient winning machine on the racetrack. It is also the first non-Japanese bike to dominate the final points table.
Model: Aprilia RSV 1000R Factory
Year: 2007
Category: Sport
Displacement: 997.60 ccm (60.87 cubic inches)
Engine type: V2
Stroke: 4
Power: 143.00 HP (104.4 kW)) @ 10000 RPM
Torque: 101.00 Nm (10.3 kgf-m or 74.5 ft.lbs) @ 8000 RPM
Compression: 11.8:1
Bore x stroke: 97.0 x 67.5 mm (3.8 x 2.7 inches)
Fuel system: Injection. Integrated electronic engine management system. Indirect multipoint electronic injection. 57 mm throttle bodies. 10.3 litre airbox with Air Runner air scoop.
Valves per cylinder: 4
Fuel control: DOHC
Starter: Electric
Lubrication system: Dry sump with separate steel oil tank.
Cooling system: Oil & air
Gearbox: 6-speed
final drive: Chain
Clutch: Multi-plate clutch in oil bath with patented PPC power-assisted hydraulic control.
Dry weight: 185.0 kg (407.9 pounds)
Seat height: 810 mm (31.9 inches) If adjustable, lowest setting.
Overall height: 1,130 mm (44.5 inches)
Overall length: 2,035 mm (80.1 inches)
Overall width: 730 mm (28.7 inches)
Wheelbase: 1,418 mm (55.8 inches)
Frame type: Box section sloping twin-spar frame in aluminium alloy.
Rake (fork angle): 24.8?
Trail: 102 mm (4.0 inches)
Front suspension: 43 mm ?hlins titanium nitride coated upside-down fork
Front suspension travel: 120 mm (4.7 inches)
Rear suspension: Aluminium alloy double arched member swingarm. Aprilia Progressive System (APS) linkages.
Rear suspension travel: 133 mm (5.2 inches)
Front tyre dimensions: 120/70-17.
Rear tyre dimensions: 190/55-17
Front brakes: Double disc. Bremo
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc. Bremo
Rear brakes diameter: 220 mm (8.7 inches)
Power/weight ratio: 0.7730 HP/kg
Fuel capacity: 18.00 litres (4.76 gallons)
Reserve fuel capacity: 4.00 litres (1.06 gallons)
Pål Martin Myhre
www.oemparts.no
Christensen
Registrert: 02 nov 2006, 18:34
Legg innav Christensen » 23 jan 2007, 22:06
Den er deilig 8)
Strive for perfection in everything you do. Take the best and make it better. When it does not exist, design it.
torvald
Webmaster
MC: Aprilia RS 125, 05mod
Legg innav torvald » 23 jan 2007, 23:10
Alecken
Legg innav Alecken » 23 jan 2007, 23:10
Tidligere admin/moderator
MC: Aprilia RS 250 2003
Legg innav Robban » 23 jan 2007, 23:11
Thim-
Registrert: 20 nov 2006, 13:33
Legg innav Thim- » 24 jan 2007, 08:51
¤Aprilia RS 125 2000 replica¤
¤Vakum eksosventil¤
¤Arrow effektannlegg¤
¤Fjernet Luftfilter blombe¤
¤Cdi blombe fjernet¤
34mm forgasser på veg!
2bb1
Legg innav 2bb1 » 24 jan 2007, 09:11
Aprilia RS 125 2006
DavidK
Legg innav DavidK » 24 jan 2007, 16:55
Sort BMW E46 Coupe "M3 style"
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Legg innav Robban » 24 jan 2007, 17:20
DavidK
Legg innav DavidK » 24 jan 2007, 18:32
Sier ikke at det er dyrt for selve syklen, men 229.990,- er ganske mye ass =p
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Lartreig
Legg innav Lartreig » 24 jan 2007, 21:49
DavidK
Legg innav DavidK » 24 jan 2007, 22:36
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Harry
Registrert: 24 okt 2006, 21:50
Legg innav Harry » 25 jan 2007, 08:34
Aprilia rs 125 05 mod
Ærråv
Pålarn
Legg innav Pålarn » 25 jan 2007, 08:42
Pål Martin Myhre
www.oemparts.no
Legg innav Robban » 25 jan 2007, 09:48
DavidK
Legg innav DavidK » 25 jan 2007, 16:43
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Harry
Legg innav Harry » 25 jan 2007, 18:07
Syns den nye er mye kulere jeg :P
Ærråv
DavidK
Legg innav DavidK » 25 jan 2007, 18:36
hehe, ja den er rå den. Men den ser så snill ut synes jeg :P Ser ut som en sommerfugl i fronten 8)
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Legg innav Robban » 25 jan 2007, 19:21
Det skulle vært en linje som markerte overgangen mellom frontlykt og luftinntak.. person liker jeg 04-06 bedre... :)
Kristoffer
Registrert: 25 okt 2006, 14:55
Legg innav Kristoffer » 26 jan 2007, 15:32
*06 og 07 er fremdelse Nydelig fordi* ;)
Pålarn
Legg innav Pålarn » 26 jan 2007, 15:34
Er det prat om R6 eller RSV? :)
Hold oss til topic nå :D
Pål Martin Myhre
www.oemparts.no
DavidK
Legg innav DavidK » 26 jan 2007, 17:12
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
Kay
Legg innav Kay » 26 jan 2007, 17:53
Aprilia RS99, soon gone.
Mads
Legg innav Mads » 09 apr 2007, 01:00
Aprilia rsv er for dyr, går for gsxr 1000 når eg kommer i den klassen:P
DavidK
Legg innav DavidK » 09 apr 2007, 07:56
[x]RS125 '06 (15hk)
[x]RS125 '03 (30hk)
VRT Leader
Registrert: 09 apr 2007, 22:35
Legg innav VRT Leader » 15 apr 2007, 22:14
Aprilia RS 125 FP 98
Tim
Legg innav Tim » 15 apr 2007, 22:16
Jeg går mye heller for r1!
Alecken
Legg innav Alecken » 15 apr 2007, 22:30
Tim
Legg innav Tim » 15 apr 2007, 22:34
Alecken
Legg innav Alecken » 15 apr 2007, 22:46
16 : Aprilia Rs 125
18 : Suzuki Gixxer 600
21+: Duacti 1098
Lartreig
Legg innav Lartreig » 15 apr 2007, 22:48
16: Aprilia Rs 125
18: Yamaha YZF R6
21+ Ducati 1098
Måtte bare rette litt opp på den lista di ;)
Tim
Legg innav Tim » 15 apr 2007, 22:50
Lartreig
Legg innav Lartreig » 15 apr 2007, 22:56
Tim
Legg innav Tim » 15 apr 2007, 23:16
gryn_cr80
Registrert: 19 des 2006, 20:38
Legg innav gryn_cr80 » 28 apr 2007, 16:47
Aprilia Mx!
Legg innav Robban » 30 apr 2007, 01:55
15-17:Aprilia RS 125 Replica 1996 (sølv)
17-18:Aprilia RS 125 Replica 1997 (sort)
18-..:Aprilia RS 250 Nero Diablo 2003 (sort/rød/sølv)
Endre
Registrert: 28 jan 2007, 23:18
Legg innav Endre » 30 apr 2007, 20:37
Fet sykkel , men har nok forelsket meg i Ducati 1098 til 315.000 kr . Dyrt , men antageligvis verdt det
GPR ? Sold.
magnus91r
Registrert: 12 jun 2007, 16:11
Legg innav magnus91r » 30 jun 2007, 00:42
Esten
Legg innav Esten » 30 jun 2007, 16:23
øøøøø
AndreasM
Legg innav AndreasM » 30 jun 2007, 16:41
Aprilia RS 125..
Lartreig
Legg innav Lartreig » 30 jun 2007, 23:21
Esten
Legg innav Esten » 01 jul 2007, 16:26
Riktig, riktig :wink: Hvis jeg får meg R6 skal jeg ikke bytte iallefall :) Rå sykkel, den vant til og med 600ccm- testen som Bike utførte. :D
øøøøø
Lartreig
Legg innav Lartreig » 01 jul 2007, 16:45
AndreasM
Legg innav AndreasM » 01 jul 2007, 17:05
Aprilia RS 125..
Lartreig
Legg innav Lartreig » 01 jul 2007, 17:26
Tim
Legg innav Tim » 01 jul 2007, 17:56
Jeg så forresten en r6 idag, helsvart og med den deilige lille potten som bare stakk noen cm ut fra kåpen <3
Lartreig
Legg innav Lartreig » 01 jul 2007, 17:59
Den er også veldig rå i hvit og rød :D
Fr1g1
Registrert: 26 okt 2006, 12:46
Legg innav Fr1g1 » 01 jul 2007, 18:34
trym
Legg innav trym » 10 sep 2007, 22:44
Nå:
Aprilia RS 125 2001mod 34hk
Suzuki tsx 89mod
Eks:
SJ92
Legg innav SJ92 » 11 sep 2007, 07:41
Sindre
|x| aprilia '03 SBK
aprilia '07 Spains nr. 1 :D
Gå tilbake til «RSV/Tuono»
