Aprilia Tuono 1000R Factory
HyPaH
MC: Aprilia RS 125 '07
Legg innav HyPaH » 24 okt 2007, 23:16
Talk about Aprilia and the word “Factory” casts a spell that transports you directly into the world of racing and racetrack victories. The word “Factory” also means the very best technology that can be applied to a motorcycle. The Aprilia Tuono 1000 R Factory lives up to its name by being the most special, most powerful, most exclusive and most refined of all Tuonos.
Here is a bike that really has no rivals. Whatever competition the Tuono has taken part in, it has emerged the uncontested winner and most impressive protagonist.
TECHNICAL SPECIFICATIONS
Colours, specifications and technical data may be subject to change without prior notice.
Engine
V60 Magnesium. Longitudinal 60° V twin four stroke. Liquid cooling with three-way pressurised circuit. Double overhead cams, mixed gear/chain timing drive, four valves per cylinder. Patented AVDC anti-vibration double countershaft.
Fuel
95 RON unleaded petrol.
Bore and stroke
97 x 67.5 mm.
Displacement
997.62 cc.
Compression ratio
11.8:1.
Maximum power at the crank
102 kW (139 HP) at 9,500 rpm.
Maximum torque at the crank
10.9 kgm (107 Nm) at 8,500 rpm.
Fuel system
Integrated electronic engine management system. Indirect multi-point electronic fuel injection. 57 mm diameter throttle bodies. 10.3 litre airbox with Air Runner ram air intake.
Ignition
Digital electronic ignition, integrated with the fuel injection system. One spark plug per cylinder.
Starting
Electric starter.
Exhaust system
Two silencers with three way catalytic converter and lambda probe oxygen sensor (Euro 3).
Generator
12 V – 500 W.
Lubrication
Dry sump with separate oil reservoir.
Double trochoid pump with oil cooler.
Steel oil reservoir.
Gearbox
6 speed. Transmission ratios:
1st 34/15 (2.27)
2nd 31/19 (1.63)
3rd 26/20 (1.3)
4th 24/22 (1.091)
5th 24/25 (0.96)
6th 23/26 (0.88)
Clutch
Multiple disc in oil bath with patented PPC power-assisted hydraulic control.
Metal braided clutch hose.
Radial master cylinder.
Primary drive
Spur gears. Transmission ratio: 60/31 (1.935:1).
Final drive
Chain.
Transmission ratio: 40/16 (2.5:1).
Frame
Box section sloping twin-spar frame in aluminium alloy.
Front suspension
Öhlins Racing 43 mm upside-down fork with adjustment for spring preload, compression and rebound damping. 120 mm wheel travel.
Rear suspension
Aluminium alloy double member swingarm. APS (Aprilia Progressive System) rising rate linkages.
Öhlins Racing piggy-back monoshock with adjustment for spring preload, compression and rebound damping. Wheel travel 133 mm.
Brakes
Front: Brembo double floating disc in stainless steel, Ø 320 mm.
Brembo radial calipers with four 34 mm pistons and four sintered pads.
Metal braided brake hose.
Rear: Brembo stainless steel disc, Ø 220 mm. Single caliper with two 32 mm pistons and sintered pads. Metal braided brake hose.
Wheels
Forged, in aluminium alloy.
Front: 3.50 x 17"
Rear: 6.00 x 17".
Tyres
Radial tubeless.
Front: 120/70 ZR 17.
Rear: 180/55 ZR 17 (alternatives: 190/50 ZR 17 and 190/55).
Dimensions
Overall length: 2,025 mm
Overall width: 830 mm (at handlebars)
Overall height: 1,100 mm (at handlebars)
Seat height: 810 mm
Handlebar height: 1,020 mm at bar ends
Wheelbase: 1,410 mm
Trail: 103.7 mm
Steering rake angle: 25°
Dry weight (without battery)
181 kg dry *
Tank
Capacity 18 litres, 4 litre reserve.
x - BMW E28 518 x - Honda MT5
"Burn rubber, not your soul"
karlsen.90
Registrert: 11 des 2006, 15:06
Legg innav karlsen.90 » 25 okt 2007, 00:20
Italian Animal
Aprilia rs 125 '05
Kjosarn
Legg innav Kjosarn » 25 okt 2007, 07:54
Aprilia RS 125 07
Motorduden
Legg innav Motorduden » 25 okt 2007, 11:06
Husaberg FS650!
Toita Celica GT4
Sierræva 92'
X: Yamaha Aerox 2002'
X: FP Aprilia RS125 2000'
HyPaH
Legg innav HyPaH » 25 okt 2007, 11:29
Kjosarn
Legg innav Kjosarn » 25 okt 2007, 13:14
Aprilia RS 125 07
karlsen.90
Legg innav karlsen.90 » 25 okt 2007, 13:36
Italian Animal
Aprilia rs 125 '05
Esten
Legg innav Esten » 25 okt 2007, 13:49
karlsen.90
Legg innav karlsen.90 » 25 okt 2007, 16:37
Italian Animal
Aprilia rs 125 '05
Kjosarn
Legg innav Kjosarn » 25 okt 2007, 17:59
Ja den stygge kladden som ligger som noe dødt nede på sida
Aprilia RS 125 07
DannyBoy
Registrert: 14 jul 2007, 17:10
Re: Aprilia Tuono 1000R Factory
Legg innav DannyBoy » 25 okt 2007, 19:11
Elsker det bildet der :D Sinnsykt gromt!
Aprilia RS 125 2000 mod<3
karlsen.90
Legg innav karlsen.90 » 25 okt 2007, 19:36
den catkilleren er enormt fet.
Italian Animal
Aprilia rs 125 '05
knudtsen
Legg innav knudtsen » 25 okt 2007, 21:17
Jolly Moto
RAVE 1
Dellorto VHSB34
BR10EG
Dyse: 145
aprilia rs 125 2002
Kelso
Legg innav Kelso » 25 okt 2007, 21:26
Rave 1 & Jolly Moto
Lartreig
Legg innav Lartreig » 25 okt 2007, 21:53
186.900 for vanlig tuono og 209.900 for Tuono Factory :)
Kelso
Legg innav Kelso » 25 okt 2007, 21:55
08 mod dette eller?
Rave 1 & Jolly Moto
HyPaH
Legg innav HyPaH » 03 nov 2007, 00:43
Det er nesten så det er verdt det :D
Kjosarn
Legg innav Kjosarn » 03 nov 2007, 00:46
Ikke 08 mod nei. kom vel i 06 etter det jeg vet.
Aprilia RS 125 07
HyPaH
Legg innav HyPaH » 03 nov 2007, 00:48
Ikke 08 modell?
Kjosarn
Legg innav Kjosarn » 03 nov 2007, 00:51
NEI! http://mcjournalen.no/aprilia/apr_tounofact_kat07.htm
Noen må få det inn med te-skje.
Aprilia RS 125 07
HyPaH
Legg innav HyPaH » 03 nov 2007, 00:53
Jajajaja! Ro ned da.. :shock:
Kjosarn
Legg innav Kjosarn » 03 nov 2007, 00:54
Når jeg skriver at det ikke er 08mod, så blir det forferdlig dumt å spørre om igjen. Men som sagt, Noen må få det inn med te-skje.
Aprilia RS 125 07
HyPaH
Legg innav HyPaH » 03 nov 2007, 00:54
Sorry da.. Det er vel kanskje ikke menneskelig å feile?
Kjosarn
Legg innav Kjosarn » 03 nov 2007, 00:57
Jaja, men burde skjønne at du ikke spør om igjen på et spørsmål som er blitt besvart, kunne blitt artig om alle på forumet skulle gjort det, men tilbake til topic. Hadde vørt fett med en annen fargekombinasjon.
Aprilia RS 125 07
HyPaH
Legg innav HyPaH » 03 nov 2007, 00:59
Okey.. Men trodde bare at det var en 08 modell jeg.. Siden den mest sannsynlig er produsert i 08.. Men tilbake til topic ja! Det hadde vært gromt.. ;)
HyPaH
Legg innav HyPaH » 16 des 2007, 12:13
Tuono vil jeg ha en gang! :shock:
KneeDragger
Legg innav KneeDragger » 16 des 2007, 12:50
veldig fet 08 modell detta her <3 <3
synes den ser bedre ut en de forrige :D
knudtsen
Legg innav knudtsen » 16 des 2007, 13:26
Spol frem til jeg er 20år og la meg vinne i lotto!
Jolly Moto
RAVE 1
Dellorto VHSB34
BR10EG
Dyse: 145
aprilia rs 125 2002
Matrox51
Registrert: 20 des 2009, 01:12
Legg innav Matrox51 » 21 des 2009, 11:55
Fin sykkel, genialt helt ned til minste detalj, ;)
Aprilia RS Tuono 125 -04
AndyCandy
Legg innav AndyCandy » 21 des 2009, 15:22
Du skal ha kreds for å dra opp en 2 år gammel topic da Matrox! :D Hehe.
Aprilia RS 125 - Black - 2006
Legg innav jaantoore » 21 des 2009, 16:36
=D> Hehe
Matrox51
Legg innav Matrox51 » 21 des 2009, 18:33
Eg e flink, men kan ikke si at sykkelen ikke er fin. ;)
Legg innav jaantoore » 21 des 2009, 19:22
Neinei, helt klart en av de kulere syklene :D
Kriston
Legg innav Kriston » 21 des 2009, 22:38
Selv om det er en gammel tråd, så er den jo fremdeles aktuell i og med at det ikke har kommet en ny Tuono. :)
Legg innav jaantoore » 21 des 2009, 22:44
Ja, jeg er værtfall ikke en motstander av folk som tar opp gamle og ofte glemte tråder :) Koslig er det
AndyCandy
Legg innav AndyCandy » 22 des 2009, 01:11
Neida, jeg syntes det er søtt jeg :D Å det er fortsatt en aktuell sak som Kristoffer så fint påpekte!
eirikoo
Legg innav eirikoo » 22 des 2009, 02:13
Bra du tar opp slike tråder igjenn. :p hehe. Det er jo tross alt en nydelig sykkel. ;)
Men din sykkel er også fin, Matrox51. Så jeg savner din tråd av sykkelen. ;) Vill gjerne se bilder av vidunderet. :D
Aprilia RS 125, 2003 modell
Gå tilbake til «RSV/Tuono»
