Aprilia Dorsoduro 750
Alt nytt fra mc-verdenen postes her
Legg innav Sigbjørn » 01 aug 2008, 11:32
Tekniske Spesifikasjoner
Engine
Aprilia V90 four stroke longitudinal 90° V twin. Liquid cooling. Double overhead camshaft with mixed gear/chain drive; four valves per cylinder.
Fuel
Unleaded petrol.
Bore x stroke
92 x 56.4 mm.
Total displacement
749.9 cc.
Compression ratio
11 : 1.
Maximum power at the crank
67.3 kW (92 HP) at 8750 rpm.
Maximum torque at the crank
8.4 kgm (82 Nm) at 4500 rpm.
Fuel system
Integrated engine management system. Electronic fuel injection with ride-by-wire electronic throttle control.
Ignition
Digital electronic, integrated in the fuel injection system.
Starting
Electric
Exhaust
Two in one system in 100% stainless steel with three-way catalytic converter and Lambda probe.
Alternator
450 W at 6000 rpm.
Lubrication
Wet sump.
Gearbox
Six speed. Transmission ratios:
1st 14/36 (2.57)
2nd 17/32 (1.88)
3rd 20/30 (1.5)
4th 22/28 (1.27)
5th 23/26 (1.13)
6th 24/25 (1.04)
Clutch
Hydraulically operated multi-plate wet clutch.
Primary drive
Spur gears. Transmission ratio 38/71 (1.87).
Final drive
Chain. Transmission ratio 16/46.
Frame
Modular steel trellis secured to aluminium side plates by high strength bolts. Detachable rear frame.
Front suspension
43 mm upside-down fork. 160 mm wheel travel.
Rear suspension
Aluminium alloy swingarm.
Hydraulic shock absorber adjustable in spring preload and rebound damping. Wheel travel: 160 mm.
Brakes
Front: Double stainless steel floating disc (Ø 320 mm). Four-piston radial calipers.
Metal braided brake line.
Rear: Stainless steel disc (? 240 mm) with single piston caliper. Metal braided brake line.
Wheels
Aluminium alloy.
Front: 3.50 x 17".
Rear: 6.00 x 17".
Tyres
Radial tubeless.
Front: 120/70 ZR 17.
Rear: 180/55 ZR 17.
Dimensions
Overall length: 2216 mm
Overall width: 905 mm (at handlebars)
Overall height: 1185 mm (at instruments)
Seat height: 870 mm
Wheelbase: 1505 mm
Trail: 108 mm
Rake angle: 26°
Weight:
186 kg
Tank capacity
12 litres (autonomy > 200 km)
Sucu
Re: Aprilia Dorsoduro 750
Legg innav Sucu » 01 aug 2008, 11:58
Så ganske rå ut :twisted:
vetizz
Legg innav vetizz » 01 aug 2008, 12:32
Pris? :D
BMW e36 cab 1998
VW Polo 1994
BMW 520
Mercedes 230TE
Aprilia RS 125 RSF
[X] Jeep Cherokee
[X] Mercedes c180
[X] VW Golf 1994
[X] BMW E21 323 cab 1978
[X] BMW 318is coupe
[X] Mercedes 230TE
[X] VW Corrado G60 x4
[X] Yamaha DTR 50 x2
[X] Sachs Madass 150
[X] Aprilia RS 125 x3
trym
Legg innav trym » 01 aug 2008, 13:29
skamrå!
Nå:
Aprilia RS 125 2001mod 34hk
Suzuki tsx 89mod
Eks:
Legg innav Christian » 01 aug 2008, 13:52
NAM!
Legg innav Sigbjørn » 01 aug 2008, 13:53
Denne var NAM ja.. Aner ikke pris, men alt er hentet fra Aprilia's egne sider.
patmat
Legg innav patmat » 01 aug 2008, 19:21
Jeg er forelsket!
RS'n selges! ta kontakt=)
extrema
Registrert: 29 okt 2007, 22:09
Legg innav extrema » 01 aug 2008, 22:27
nå vet jeg hva jeg skal spare penger til! :shock:
-1994 aprilia rs 125 extrema! fp anlegg, rave1, 34mm DellOrto.
vetizz
Legg innav vetizz » 01 aug 2008, 22:33
Det gjør jeg også, jeg skal spare til Kawasaki 750 h2... Hva skal du spare til da? :roll:
BMW e36 cab 1998
VW Polo 1994
BMW 520
Mercedes 230TE
Aprilia RS 125 RSF
[X] Jeep Cherokee
[X] Mercedes c180
[X] VW Golf 1994
[X] BMW 318is coupe
[X] Mercedes 230TE
extrema
Legg innav extrema » 01 aug 2008, 22:37
skal ha en sm med over 500ccm iallefall :P broren min har kjøpt seg husaberg 450 å den er syk!
Å denne går jo sikkert enda bedre :D
vetizz
Legg innav vetizz » 01 aug 2008, 22:58
Kjøp kåtemenn 380 totakt! VILT! :D
BMW e36 cab 1998
VW Polo 1994
BMW 520
Mercedes 230TE
Aprilia RS 125 RSF
[X] Jeep Cherokee
[X] Mercedes c180
[X] VW Golf 1994
[X] BMW 318is coupe
[X] Mercedes 230TE
fullpower_rider
Legg innav fullpower_rider » 01 aug 2008, 23:01
Den motoren passer så og si rett i rammen på min ktm exc 125 ;D har planer om å sette in en slik motor i min ;D
vetizz
Legg innav vetizz » 01 aug 2008, 23:08
Nice! Husk å lag en bra og ryddig worklog med MANGE bilder. :D
BMW e36 cab 1998
VW Polo 1994
BMW 520
Mercedes 230TE
Aprilia RS 125 RSF
[X] Jeep Cherokee
[X] Mercedes c180
[X] VW Golf 1994
[X] BMW 318is coupe
[X] Mercedes 230TE
Sucu
Legg innav Sucu » 01 aug 2008, 23:51
fullpower_rider
Legg innav fullpower_rider » 02 aug 2008, 00:01
Den er hvet jeg att jeg kan sette rett i rammen på ktmen :) får se om jeg ikke finner en billig motor ;D
trym
Legg innav trym » 02 aug 2008, 00:02
*missunlig* :shock:
Nå:
Suzuki tsx 89mod
Eks:
Legg innav jaantoore » 02 aug 2008, 01:12
er det ikke sånn at 125 og 200 har samme blokka da? 380 blir jo villt da :twisted:
trym
Legg innav trym » 02 aug 2008, 01:28
Kan nok rime seg det, har sett flere ktm 125'er som er blitt ombygd til 200.
Nå:
Suzuki tsx 89mod
Eks:
Legg innav Sigbjørn » 02 aug 2008, 01:32
Déjà vu
Hold dere til emne som er: Aprilia Dorsoduro 750
Legg innav jaantoore » 02 aug 2008, 01:44
Okei.. :P Skikkelig fet sykkel!
trym
Legg innav trym » 02 aug 2008, 01:45
Ingen tvil
Nå:
Suzuki tsx 89mod
Eks:
Mathias
Registrert: 19 des 2006, 18:30
MC: Aprilia Rs 125
Legg innav Mathias » 05 aug 2008, 22:04
APRILIA RS 125 07 spain's #1
Free Power
trym
Legg innav trym » 05 aug 2008, 23:06
Syns den var litt overpriset.. :roll:
Nå:
Suzuki tsx 89mod
Eks:
Øystein G
MC: Aprilia Rs125 '07 Black
Legg innav Øystein G » 06 aug 2008, 00:07
Var jo ikke så aaaltfor villt men ville ikke gitt mer enn 120 maks for en sånn..
Fp ++
Gå tilbake til «Nyheter»
