varsellampe
varsellampe
Kom opp en rød trekanta varsellampe med utropstegn når fattern tok en tur på sykkelen i stad, men har ikke manual og sånt så lurer på hvorfor den lyser/hva som er galt ? Olje nivå er sånn det skal være
APRILIARS125
Rave 1
Arrow exhaust, stock lyddemper
Vforce3
Dellorto vhsb 34mm
Uplombert luftfilter
140 dyse
Nåla i øverste hakk
Ngk br10eg
Rave 1
Vforce3
Dellorto vhsb 34mm
140 dyse
Nåla i øverste hakk
Ngk br10eg
KennethOisann
- Nysgjerrigper
- Registrert: 09 jul 2014, 00:21
Re: varsellampe
Fra serviceboka
"Comes on when the ignition switch is set to "circle " with the engine stopped as a lamp test. If the light does not come on in this phase, contact an aprilia Official Dealer. If the light remains on after the engine starts or comes on during the normal operation of the engine, this means that low fluid level in tank and mixer or high coolant temperature was detected. In this case, check and/or top up to recommended fluid level and contact an aprilia Authorised dealer, if necessary."
