Hvordan fjerne 78 kw sperre fra 2008 RSV Tuono R?
Tommybrokhaug
Registrert: 25 nov 2008, 18:47
Legg innav Tommybrokhaug » 08 aug 2011, 15:44
Hei.
Har problemer med å finne ut hva som er forskjell på fulleffekt og min sykkel.
Min står med 78 kw (105 hk) og maksimal konstruktiv hastighet 234 km/t i vognkortet.
Virker som veldig få har vært borti dette før.
Folk jeg har snakket med som ikke har noen erfaring fra Aprilia eller nyere sykler, tror det kan være alt fra software til blokkering av gass wiren.
Selv har jeg ikke fått satt meg nok inn i hvordan sykkelen fungerer til å tro noe som helst.
På forhånd takk.
Tommy
2011 Husqvarna TC449
2008 RSV Tuono 1000 R
1998 RS250
adrtree
Registrert: 23 feb 2011, 19:09
Re: Hvordan fjerne 78 kw sperre fra 2008 RSV Tuono R?
Legg innav adrtree » 09 aug 2011, 15:15
Hmm. Where did you have the bike Dyno'd?? I have seen very different Dyno numbers depending on the machine used for testing. Also did you measure rear wheel HP or crank HP because these numbers are very different. Rear wheel is much much lower than flywheel/engine/crank hp. Your bike should be 140-145hp at the crank. Which would make rear wheel much lower than 140. It is strange though because top speed should be closer to 265-275 range. My 2008 RSV I have ridden to 260km/hr several times.
I have seen RSV1000's measure as low as 135hp at the crank on Dyno. Meaning rear wheel hp would be 120-130 or even lower.
A combination of Dyno machine error+lower rear wheel hp could explain the number you are stating. No 2 Dyno's ever come out the same. Some read lower some read higher
Is your bike set on factory Computer setting or Race program??
These are just ideas I could be wrong.Example, My ZX10 measured 184hp at the crankshaft but at the rear wheel it measured 152hp.
ALso if you take the bike to Aprilia they have a computer to set your bike to the Race/Track tune setting which would get rid of a speed limiter if the Tuono has a speed limiter. You must change exhaust before changing the setting though. :D
Legg innav inunf » 09 aug 2011, 18:41
Dette er sikkert et norsk fenomen, 106 hk er jo det Erling Sande har brukt å selge gixxerene med for å spare penger på registreringen. Hvis dette er tilfellet og aprilia er noenlunde som Suzuki så antar jeg at det er snakk om elektronisk plombering, og den KAN hende at en ledning kan klippes. Tror jeg ville vurdert å kjøpe en brukt hjerne fra utlandet, tipper det fikser problemet (men jeg VET som sagt ingenting).
Tommybrokhaug
Legg innav Tommybrokhaug » 24 aug 2011, 19:58
Har snakket med forhandleren. De skal høre med importøren for å finne ut hva som er forskjell.
Har garanti, så er nok greit å la dem ta det for å ikke miste den. De sa i hvertfall at det fikk være mellom meg og staten hvis jeg ble tatt. de bryr seg ikke.
Tror jeg venter til våren uansett fordi jeg skal ha nye potter da.
adrtree: The bike is new. It is restricted from the importer because of taxes.
1998 RS250
Tommybrokhaug
Legg innav Tommybrokhaug » 28 mar 2012, 20:39
Jeg fant jeg fant. Nå går den som den skal.
http://www.apriliaforum.com/forums/show ... ost3066038
1998 RS250
xavi0n
Legg innav xavi0n » 28 mar 2012, 20:50
På alle suzuki gsxs/r så er det bare ei rød ledning som du napper ut av ecu'en
Tråden min
viewtopic.php?f=26&t=8588
Legg innav inunf » 28 mar 2012, 21:45
Ja, der kan jeg se, GSX-R var ikke relevant i denne sammenhengen. Bra at du fikk fikset det Tommy!
Fubb
Legg innav Fubb » 23 apr 2013, 11:06
Enkelt å kjapp måte å ordne langt mere effekt! Skal prøves! :g :g
Fubb
Legg innav Fubb » 12 mai 2013, 16:12
Null sperre igjen og sykkelen går som en kule 8) 8) 8)
Gå tilbake til «RSV/Tuono»
